that's not a very nice thing to say about ur mum lol
dude my mums really sick
Well least he f**ks something mohsen lol
And has a skyline
So he sorta wins.
But man! No more fat chicks kthx
would rather f**k a brick
you better be ther!
ME?..dont think so...i work on the weekends...taking 3rd off for my birthday..then planing to take 14th of Nov for show n shine and 20th of NOV for DECA...if i add the 30th Oct full weekend...itll be too many days off ill be asking i they will prob say no to all...so not sure yet...ill ask but only if i have annual leave too...
lmfaooo nick my mums fine (knock on wood) fark your a dirty kent :(
boz, even if i did get laid, wouldnt stop you guys from goin on about it lol
anywho, ill leave this here
lol ;)
mmm stewies car, its fucked at the front now :laugh:
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
