thought id do this modifying thing properly and instead of just getting power i decided to make my suspension better, i just bought a bunch of nolathane bushes, nearly there whole catalogue for the gtr. cant wait to see what it feels like when its all fitted :)
lol slow at replying
Ice cream on lygon, then Eureka Skydeck. Guaranteed date win.
Yeah date win
bahahaha nah man we just seeing where things are going.. shes a smart girl so don't want to screw things up :)
Sounds like a good idea actually, maybe save it for a more warm night
nah no need for a warm night.... i always get ice-cream with missus down lygon the gas heaters they have along there keep you warm while you eat
This is true :)
Hurt much?
A little bit.. 1st session for the outline took 2 hours which hurt a fair bit especially on my ribs then the other 3 sessions were only an hour. Last session was the top part which I thought was gonna hurt like hell again but I couldn't feel it.. I was more relaxed I think cause I knew it was gonna be finished :laugh:
shan how would 17x9x+20 go on an R32 taxi?
thankss, lots of love, xoxo.
(change my name back kunt :) )
lol that would need some serious flaring and camber to get right. Will be scrub central on the front.
17x9 +30 is the ideal setup for r32 gtst's.
thats what nisskid recomended with stock guards and low.. any chance sedans are different?
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
