7.0 +40 isn't that bad on a cube actually. it's just offset out like a mofo, so no concave/dish.
16" is a bit weaksauce though. 17" minimum to look baller.
Unfortunately they start getting too wide in 17's for the design I like. 16's are a bit easier and more available.
You're right, 7.0" ~ +35 is about the limit before the inner guards need rolling.
This is what 7.0" wide, +15 offset looks like. Get your mexican hats ready:
nice billy,
you been to the top gear test track?
come get me this saturday my car is running again
you still at supercheap? if so i need fire extinguisher and those socks for fluid bottles. thanks :P
Yer had a look the other night too much rubbish on the strip!
If I do go anywhere I'll let you know :P
I need to buy an extinguisher too, just waiting for our usual buy one get one free sale, let you know :P
yeh thanks need it soon but cos of winton :P
yeh gotta go a bit off road to get there apparently.. i havent been only get car started the other day LOL i better take it out tonight though keep the battery charged :P
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
