Unfortunately they start getting too wide in 17's for the design I like. 16's are a bit easier and more available.
You're right, 7.0" ~ +35 is about the limit before the inner guards need rolling.
This is what 7.0" wide, +15 offset looks like. Get your mexican hats ready:
should work well with those optional flares then
kris' car looks like a bag of dicks encrusted with mandarin rinds, but he makes the power to make up for it. so in the grand scheme of things it's a good car.
when all your car is good for is looking good, you wanna make sure it looks impressive. so your car will look like a sugarcube with average wheels. woo fuckin hoo.
17"x8" +27's, thinner rubber, factory option flares, drop. instant epicness.
Care-factor is registering in the minus ;)
yeh thanks need it soon but cos of winton :D
yeh gotta go a bit off road to get there apparently.. i havent been only get car started the other day LOL i better take it out tonight though keep the battery charged ;)
I've got Saturday off, hit me up, it's gonna be a nice day. Maybe GOR? ;)
fkn NICE
ohhh Hamish
lol... that was the plan.... but i'm gonna sell up before it gets to that ;)
Why does it have to be anyone else's definition of good? I'll do what I want. I've never modified my cars for the enjoyment of anyone else. I pity the people that do.
Yes of course, each to their own. Some people have style, others don't.... they stick with the norm. I pity those people.
Cars are like fashion. Some people like shopping at Big W and others enjoy designer brands. I modify my car to suit my style/personality.
Goodluck, Can't wait to see the Cube.
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
    • Hi.. Just another problem. So maybe you can help. I(my mechanic) done swap from my RB20DE NEO to RB25DET NEO. Everything is OK but we have a boost cut. Coils/Plugs are ok...AFM is ok. ECU is ok. I have Walbro 255 but it "changed" sound few months ago(you can hear it ouside) you did not hear that when it was new(maybe faulty?) Sooo...what now? What can cause this boost cut? It is even when you standing still...
