I've got Saturday off, hit me up, it's gonna be a nice day. Maybe GOR? :P
yeh i got work till afternoon like 2ish i think :/
Yes of course, each to their own. Some people have style, others don't.... they stick with the norm. I pity those people.
Cars are like fashion. Some people like shopping at Big W and others enjoy designer brands. I modify my car to suit my style/personality.
Goodluck, Can't wait to see the Cube.
salvo's style ftw!
Where do I get those hats from? Look much nicer than the 18yr old standards hats im using..
i made them on the lathe, couldnt find anything off the shelf that suited what i wanted. u can buy tein uppers, but they are rose jointed i think, which is pretty much useless on a road car. and im not sure if ur coils are the same OD.
any tyre shop that sells wheels should have them.
wouldnt worry about price, for the effort and fuel, it's not gonna make much difference, few $$ max.
for custom's it ran me $140
for the bob jane specials it was like $25
do a ring around first, as many places have no f**king idea what they are, it took me 3 visits to get them from bj's
Decided to sell my 20mm spacers.. Not worth all the hassle. Going to try for a 5mm (just a normal one).
what hastle?
can you please for the love of god just do what we say next time? it's not like we're trying to fuck your shit up.
I tried to get a set for teh cef, and no one could get em, so I just went down to the wheel shop down the road from the workshop and the guy milled four out of chromolly for me on the lathe. cost me $30 in materials, a can of coke and a burger with the lot for his lunch.
yeh.... cenreline did mine as the car was already there.... so i paid the centreline tax :laugh:
Flaring the guards, respraying it if it cracks etc.
Plus it'll affect the handling too much. The MR2 boys talked me out of it.
spacers take the shear weight off the hub studs = bad for studs
you get heaps more chicks without spacers
fact
ill be very surprised if an average girl would even know what spacers are.. :laugh: ..the girls who are highly involved with cars would know but not others...so ill like to challenge your fact :D
fact
this.
you know what, fuck it. listen to your cock jockey mr2 fanboy mates. just picture your wheel rolling off in another direction as you corner, followed by a massive scraping sound as your brake disc/control arm/sump grinds into the asphalt. cos it could happen anytime with that setup.
for some reason i have spacers in my car...i agree spacers are gay...get fat wheels instead...hehehe...
Too late lol. I already have all my wheels :laugh: Fronts poke out heaps and rears are tucked in lol
Too late lol. I already have all my wheels :D Fronts poke out heaps and rears are tucked in lol
i like the back one to stick out more for better looks...but ey thats my taste...lol... :laugh:
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
