Dude, I just spent $700 repairing these wheels. If I sold them I would even get what I paid for them (which was too much for starters). :laugh:
Will definitely make the wheels wider if it's cheap enough.
whitehorse industries i think its called?
for real, i feel bad for you come in here ask for advice and get burnt to a crisp everytime.
sell the wheels u got now, get the right wheels through streeter or something worth the wait and save ya self f**kin around.
:laugh:
probably the most worthwhile post i've ever made, someone quote this shit.
there
make wheels wider?
even if it is possible, it wouldnt be cheap
Sweet! This sounds like a good option..
I really don't want to sell my current wheels after spending so much money getting them repaired and redone in a custom colour.
Edited by jezza boii
except that the wheels that you've got can't be widened. good luck with that.
I won't say the business that I bought the wheels through.. but I was expecting them to be in good condition.
Turns out they were structurally damaged and needed extensive repair work.
Wheels were: $1650
Repair: $700
Tires: $1100
So around $3500 all up. Worth over 40% of the car price haha...
Wheels were: $1650
Repair: $700
Tires: $1100
why didn't you test fit beforehand? :laugh:
why didn't you test fit beforehand? :blink:
Coz I paid for them before they even landed in Australia.. Plus I knew the rears would be tucked in. These are the wheels that Hamish suggested I get. He said I would want a 10mm spacer though.
N00b question.... Would it hurt to have a little bit of positive camber in the rears? So they look wider than they really are? And then a little bit of negative camber in the front?
Or would that make the car handle like a bag of dicks?
do not run positive camber in the rears. It'll mean when you corner your rear wheels will have minimal contact with the surface. your car is already snap oversteering inclined cos all your weight is on the rear, guess what happens when you have no grip as well in the rear?
Find a 10mm spacer and STFU
10mm/15mm bolt on spacer. then STFU, get your balls in a bunch and roll your guards. do it or I will punch you in your sandy, fickle, good advice ignoring vagina. yes, this justaposition implies you're a hermaphrodite. deal w/ it.
Or cut your losses, sell the wheels and actually buy ones that will fit instead of ghettoing it up, and getting cheap shit on a whim that it may fit.
Where do I get a 10mm spacer with hubcentric rings to suit? I could find any. That's the only reason I went for the 20mm
I really can't afford to count my losses.. I'm running out of cash very quickly. Still need to get a new gearbox and address the rust that is starting to appear.
http://www.nissansilvia.com/forums/index.p...howtopic=406553
15mm then man up and roll the guard.
you can get 10mm from the US/Japan, but expect to pay a lot more.
Like these:
Like these:
Rear guards are already rolled. Wouldn't they need to be flared though? My fronts hit the guard like a mofo and they're only sticking out 6mm.
15mm spacers in the rear would mean 10+mm out of the guard.
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
    • Thanks for the replies everyone. Definitely a coolant push. Oil catch can is empty and always has been. As the engine is out now I'll be having a good look over things. I do have some detonation on the piston tops from a trigger issue back about 5 years ago. I felt it and shut off then bought a new ecu and changed the trigger. Never been an issue since. It never hurt the power, its made almost 80hp more since that incident but I will pull the bearing caps to take a look. If the bearings are damaged I will do a bottom end refresh. Head is being re conditioned at the moment and the block will be cleaned and checked to ensure it's flat. I'll go with a kameari gasket and see how it ends up. The other thing I'm not super keen on is the cylinder colours. I suspect this is from the inlet manifold. The plan will be to put it back together, retune and then stick a plazmaman billet inlet on it and retune. I'm happy with the power, if it makes a little more, then great, but I would rather just make everything more efficient at this stage.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
    • Does it also misfire equally when revving?   Josh is very correct in what you should do. The coilpack harness wiring loom itself is a known problem due to its age and the number of heat cycles it has gone through. Throwing parts at a vehicle to diagnose the issue isn't a smart or good way to do it. Secondly, you may have a bad coil pack, you pop replacements in, they fix that issue, but messing with the harness breaks it, so the issue persists. So now you think "well it wasn't the coil packs" and have to continue chasing your tail, potentially swapping back in your shit coil packs and returning the good ones (yes, I've seen people do this because 'it wasn't the problem' and they want to save money). And suddenly, you've got two issues with the same symptoms...   Diagnose, don't use the spare parts shotgun.
