chasers?
Nah, the mechanic opposite my work who does all of my cars now. Honest, knowledgable, reliable and cheap. Not giving his name out publically though as they're a two person shop and already have plenty of customers to keep them busy. PM me if you want the contact details.
It doesn't take a lot of effort to find something unroadworthy/illegal on a skyline. Your restriction is just another headache ontop haha.
i know, its quick enough for me at the moment, loving how east and effortless it is to drive.
im also very surprised with the condition of it, the floormats are still in excellent condition! lmao
also found this inside it.. what is it?
of course, you were meant to do that before you bought it
correct, put it in my mums name lol
lol, he wont listen to anyone his like me when I was that age, I was a fraction away from buying a 32 GTST but good thing I didn't the first week of owning the N/A got pulled over and checked for turbo etc.
All the best with it Mohsen, if you get f**ked by cops just buy another car straight away.. keep the 32 in the garage for 4 years. Then it will only be a 25 year old car :down:
thanks dude, hopefully i dont get any hassles, its not like i drive like a manyak or anything.
im not gona drive it on far untill i get an exemption too.
edit:
kinda what i want my car to gradually look like, minus guards
Edited by Mohsen
Looks like a 0-100km/h & 0-400m timer. Records how long it takes you to achieve either one.
no, i need to get my p's first
Why? I don't remember any part of the rules saying you have to be on your P's to ask them if the car is legal or not.
i actually rang them and asked them. they said i have to have my p's before they allow it.
finished the stupid logbook, just have to book them and go for the test.
also, shan, would you know where the valet switch is
in the boot...
i read somewhere theres a little lever for when you want to open the boot with a key or the pulley thing.
the pulley thing wont work and someone said its the valet switch/lever. DOING MY HEAD IN
    • f**king around with the bro
    • Ludenham   44.2 tops day no issues
    • Then today, I went to visit a man with an r33 hat Peter and Road and Race sorted the alignment. As it is being set up for general track/hillclimbs etc it has a heap of caster (7o), less camber than I am used to (1o front and 2o rear, as the caster looks after that in turns without the braking downsides), 3mm front toe out and 0 toe rear. Will see how that goes and track tyre wear to see if it does need more camber, but adjsustment is also limited with nismo arms and adjustable bushes at only 1 end. It does have a bent inner tie rod on the driver's side front but as it came up within spec I'll just leave that as is. So, that is getting close to my chapter of this story....could of tidy ups then a shakedown in early October before it finds a new home.
    • So, it went to Unigroup for a run in and tune on Friday, everything went (generally) well. In terms of fixes, the engine was good and there were no leaks. It needed plugs (I hadn't checked them because the coil pack cover was on a new engine and I couldn't imagine they weren't new.....but turns out the temporary plugs to just keep it sealed up were in there.....new plugs gapped to 0.8 and it was fine from there. Also, there was a little preload on the clutch slave which caused some slip. I haven't had the box off so I don't know what the clutch looks like; my guess it is brand new and the pedal had not been adjusted....backed that off a bit and it held fine. Last thing will have Dose crying....the idle especially when cold is a bit difficult between the cams, forward plenum, atmo blow off valve and an 80s air management system. It is fine when hot but a little uneven when cold, will see if I can sort or at least improve that one cold morning. Other than that, tuning went fine. It made 245 but was pulled back to 227 which 2 opportunities to improve in future. 1. The factory CAS is not great and was jumping around at high RPM, so Mark took 2 degrees out up top (that is why it stops making power and lost 20kw). Very safe this way and the extra power is available but will require a more modern ECU and better cam (or even better crank) sensor 2. The 2871 in factory housings is very big for a low mount, and the internal wastegate is too small, so it was creeping from mid range all the way to redline....the duty cycle on the boost controller is turned down a little for safety. That is much harder to fix, it would need a large external gate and that would require a whole bunch of other changes, so it will go as it is for now. It feels nice and healthy and safe, so should be good for about a billion laps like this.
    • what sort of caliper are they? If they are a slider and you gave everything a good clean, you might need to regrease the pins. My guess though is they will come good after some abuse as suggested above
