Just as long as Mohsen doesn't start spreading. I'm outta here if that shit happens.
Edited by jezza boii
f*&k ya....around 11 ya? ill try to make it and if not call you when i am on my way to make sure u still there...
practise makes perfect!
And the non-snarky version of what happened- thanks Jeremy, ur snide comments just always make me feel loved- is that I hit a massive pothole on the western fwy outside ballarat at 110kmh (was dark didn't see it until last sec and couldn't avoid it) and bent the rim :D( n broke my steering rack kinda :ermm:
btw cas...
http://page7.auctions.yahoo.co.jp/jp/auction/g91619685
17x9.5" 114.3 PCD.
$260 buy it now for 3 + shipping costs + agent costs + international freight.
use two of em and have one as a spare. or get streeter to just chuck one out and send 2 to save on shipping.
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
