Whats happenin Jamie, Havent seen you in a while.
It was about 2 weeks ago at Garage Cafe :)
Just working and taking it easy.
Hey you still looking around for ppl to fix your rear bushings or whatever needs done?
My friend owns JAK Motorsport (Former as Drift Line)
Jack from Chasers works there now and he can probably quote you up on a price to fix.
Yeah gotta catch up soon.
yeah Oettinger 500ml cans are about all I drink these days, $42 for a slab, can't go wrong! (esp when CUB slabs are $48 fkn dollars!) $35 for slabs of most German beers at the Liquorlands / Woolies around here too, its great!
Boags is vile man, forced myself to drink a slab of it last cup day, shitful.
hame thats a fair intake of alcohol mate. might wanna watch that
/medical brain
everyone loves corona yes, but you gotta use lime. lemon is for wimmin. others that are on my regular list are asahi, beez neez, little creatures pale and golden, james squire, becks, bluetongue (white rabbit is pretty similar to this too), heineken, boags. guiness goes down a treat too
i try to drink something new as often as possible. dont drink spirits as much nowadays but partial to a bit of CC and Hennessy. can not even smell vodka after a certain incident a couple of years back lol
on tap at Shou Sumiyaki was the best :)
*Free
fucken tightarsed maso's :)
the mechanic from driftline Monty works at chasers now.
divided. I should go to Jak cos well, it's the old stomping ground, but then Monty knows his shit, and Kamikaze's on my side of town. decisions. decisions.
boags is ok in light form, heavy is horrible
cascade is good, light or heavy
vb horrible period.
carlton draught, not bad, a light form would be goooood
carlton cold, good as a heavy
tooyeys (however its spelt) extra dry = my fav heavy beer
tooyeys one with the lime, pretty farken good to for a heavy
dont like corona
tooyeys red, good for a cheap heavy
Mate ofmineis dropping a tt engine into his na poopra thru JAK. I was recommendind driftline to him recently. No idea that they're the same joint now.
Where's kamikaze?
Where's kamikaze?
lol yeah sold up the business, jak still pays rent tho :P they also paid for the shittonne of spare parts we had in there.
Where's kamikaze?
Is your mates Supra that, off colour Bronze / Titanium Grey 1 with the body kit?
It was about 2 weeks ago at Garage Cafe :P
Hmm yeh still need new subframe bushes but i've been saving to get the corona on the road which should be happenin this/next week if everything goes well :rofl: then I'll put the GTR away for a while till i get more money to fix it up.
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
