i'd rather not. i've already blocked you from my feed so i don't have to put up with your faggotry. besides, what kind of insecure shitkent makes their car their profile pic?
someone who just bought it lol
i spend nights, just sitting there thinking why you blocked me from your feed... it broke me
I've bought more cars than you've had birthdays and I haven't had the urge to make any of em my profile pic. What's wrong with your face?
seriously, if I ever see someone on fb...
with a pic of their pet: socially retarded, doesn't have any real friends.
with a pic of their gf: nuts stored in a jar, at their gf's place, in her dungeon, next to his gimp mask and gag.
with a pic of their car: poor kent that pours all their money into a car thinking what they drive is what defines them socially.
with a cartoon: no self esteem, ugly kent.
with a zoomed in pic of body part: only part of their body that doesn't make them look like the result of genetic/drug testing
with a myspace angle pic: bozo's gf
very accurate
im more intrigued about the cars though
please tell
    • Lamb roast on Saturday will be different 🥲
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
