paid $100 for mine. 2 din touchscreen dvd mps gps bluetooth usb etc etc
im surprised it still works...
they arnt all bad, had mine in car about 6months and its been fine the whole time
rather cheap it out than spend what i will be spending to go to Singapore and Thailand next year one DVD player for my car
Anyone been to London before? Whats the most central hotel close to all the touristy bullshit? Anyone have any recommendations?
Cheers
I was there a few months ago. Stayed in a hostel, it was brand new which was great. It was called the YHA London Central Hostel. It was a 5-10 minute walk to oxford street and the Oxford circus (tube station) from there you pretty much catch the tube everywhere. Easiest way to get around and almost every touristy place is 3-4 stops away.
ah cheers. Might give the hostels a skip (especially during the cold months now)
So what is the most central/popular area to be in London? Will look around that area for a hotel.
Cheers
yeah, dont go to london
wats happenin!
Need recommendation for Wheel alignment, anyone? westside preferably or close
centreline
cleaning up my old seahorse tank to set it up for tropicals....
CBF going marine again... too much $$$ to set up properly and dont have the time :P
just stained the base to match the furniture and scrubbing in and out etc :P
what you looking at keeping? i've got a batch of about 150-200 baby blue rams that im trying to grow out. should be ready to sell in about a month (and a half mebbe). free for you and any other wasteland fagels who want some
i might take you up on a couple of them... they are alright to live with non-cichlids yeah?
this is my first tank that is not marine, so it's all kinda new
yeah they are top little fish. only aggro to each other and mostly at breeding time. dont take shit from other fish though. they wont do damage unless you keep two pair in a small space cos they like to set up territories and will defend. too small a space and one fish will get picked on. also they like it hot 28-30deg C. most tropicals wont like that, but do your research
if u manage to breed the f**kers, you're in for a treat cos they actually look after the babies for a few weeks to a month. sure to make merowyn go 'nawww'
also tropical is much easier mang. i dont even need to mess with my tapwater other than hit it with some seachem prime to dechlorinate
nice.... i'll have to look into the temps as i wasn't expecting to go that high.... dont know much about cichlids.
i'd love to go marine again, but i'm not going to do it in a small body of water and i'm not restumping a rental house :P
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
    • So M12 and sealant should be fine?    NPT ” because that’s what I had and what I could get atm.
    • Wouldn’t touch par if they gave it to me. You need to ask how much power you’re looking to make and then add about 50% to it because that’s what you’ll end up making  The factory box says no more at about 350kw or so, the upgraded synchro boxes won’t handle much over 500kw for long and at that point you’re looking at an auto or dog engagement manual,  once you’ve gone dog engagement you may as well go sequential, they cost a little bit more but it’s worth it  also while you’re at it you should upgrade the transfer case with 10 friction plates
