Car shit has to be settled legally now since the pricks wanna wash their hands of it. Like with lawyers and ombudsmen and shit :ermm: I am now in the market for either a) people who can hook me up with shithot legal personnel or b) a gun to put in my mouth cuz at this rate it'll be this time next year by the time the r is back on the roads.
f**k my life.
(too serious for acronyms.)
from the pothole?
f**k my life.
Have you spoken to the ombudsman?
Having worked in local government for a few years, if there's one thing I know it's that the ombudsman gets 'em sweating!
from the pothole?
yes.
will call them after a bit of a time out to untangle thoughts n work out what I need to say. Pays to be prepared.
let us know what its like, i think its exact same as iphone, but i would like to be proven wrong
yes the structure is literally excatly like the iphone...didnt get it yet..the place didnt have any in stock....he said he will have some pieces by next week...been a very popular choice it seems....but one of my mates have it and i did play with it...no complains yet from him or any other person who had the phone yet unless they are an apple fan :ermm:
drove to work this morning
car sounds like a rexy and runs like shit :P
afm?
plugs?
coils?
probably a fkd coil / plug
1 st step check your plugs
This.
sweet will check when i get home
also realised. buy a skyline, bye bye social life
It isn't that bad until you've impulse bought another one like I did... Now that's throwing your social life into toilet.
also realised. buy a skyline, bye bye money
fixed.
Social life is ur own decision. N considering u still can't drive unsupervised I don't see how it's changed anything for you.
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
