so I've been reading up on pre 1983 ADR's. I'm allowed to run 96db exhaust and don't require a Catalytic converter... muhahaha.
If you put a newer engine in does it then get based on the engine?
anyone else updated to the new Live messenger?
What a piece of shit...
yeah i ended up un-installing it and going back to previous version due to how fcuking bad it was.
msns shit in general
worst when you get random bot adds
Edited by Mohsen
what do you guys use instead of msn?
I use email, Facebook chat or Skype. Msn doesn't work properly on my Mac anyway.
On another note, if anyone has a Youtube please do me a favor and hit "like" on this video.
www.youtube.com/watch?v=iAK3xcDtSAg
I know it sucks but I'm just trying to get my name out there as a songwriter, not a singer :) Obviously.
Would appreciate heaps :)
Also, feel free to do the same for
and
Jaaaamieeee still on for tonight at rice-o-barn
Hell Yeah man!
See you there and bring money, so don't have to wait for you to goto ATM :down:
its fk-o-barn...rip ppl off...hate them....well the ones i have been to...
Haha!!
You'd have to be pretty stupid to accept them...Or you think you're gonna get laid by the 'chick' adding you
I don't really use MSN, only speak to 2 or 3 people on there these days, and for quick access to emails..
The new update is f**king terrible though
cant...have to fix my commodore...the freak drivers window came off the railing and is stuck inside the door....have to take the trim off tonight and shit to fix it....need it done tonight coz i cant drive anywhere freely in it since the car is exposed...if you know what i mean...
I know it sucks but I'm just trying to get my name out there as a songwriter, not a singer :down: Obviously.
Would appreciate heaps :P
and
the camera is above the screen. Just looks like you're eye f**king yourself lol
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
