the only people who'd be envious of your R32 are 4 year olds on tricycles cos you have 1 more wheel than them. However even they don't need their mum to supervise em while driving, so I'm sure they too wouldn't be envious of your shit.
i actually agree.. its an old r32 taxi haha
whats to envy
i was thinking of buying a front pipe for the gtr but im not sure now because the stock one doesnt look that much different to the aftermarket ones, plus they say that the dump pipes are good in the r34gtr so i dont have to worry about that either. maybe i should just get an aftermarket ecu instead.
R34 GTR Dump Pipes will be fine, but I'd change the front pipes (get a full / turbo back exhaust).
I did on my R32 GTR and the exhaust flow is so much better.
You could do ECU, but if you don't have any extensive mods, it's not much point as the stock ECU can handle what it is doing.
ive already got the catback and got a new cat ready to be put in. but after looking at pics of a stock r34 gtr front pipe and aftermarket ones i dont see much difference and the sizing doesnt look small either so i just dont see much of a gain for the price of these things. so i thought id just put it towards an ecu instead and help with the very rich tune it has. but if anyone knows better with r34gtr's and there front pipes and what i should do id like to hear from them :P
get a blow of valve that goes sututututu
it. gets. bitches
you have no clue
im not after bitches im looking for broad minded persons.
edit: ok it doesnt let me say s-l-u-t-s
sluts
uras kit acquired.
thought you were selling?
go to any club on a friday or saturday night
you have no clue
being sarcastic mannn
sluts
ahahah i know the secret!
    • What copper washer do you guys use on the bleeder bolts? The existing one I have I had no idea where to find it in a local store, I did buy some online but that are only 1mm thick whereas my old one is 2mm+ thick and when I put the new washer out and squeeze the top radiator hose I can hear a bit of air but not with the old one. Does this matter? The new one doesn't leak, but the inner diameter is a bit loose whereas the old one threads on the bolt.
    • Howdy all, after being out a few weeks ago on a spirited drive in my GTR I have 2 issues that oddly have appeared at the same time. Whilst accelerating quickly through the gears all of a sudden i’ve lost power at the top of third gear (below redline around 6000rpm) for no obvious reason.    From that point onwards the car has been running rich on idle, won’t really rev under load without a ton of black smoke and the odd backfire, and dying as a pull up to a set of lights unless I keep the revs up around 1500rpm. In addition when shutting down the car that same night (I was 10 minutes from home) I noticed one of the turbos was significantly noisy on wind down when shutting off the engine. After letting the car cool down overnight it starts up fine, although once it gets to temp the revs start to creep up and down, the exhaust is darker than it should be and it also sounds like it’s running rich (fat note) I’ve put a new set of plugs in it - no change, the old plugs all seemed OK with two of them being somewhat richer/fueled up than the other 3 with 1 being borderline. I’ve smoked tested the intake system via the front of the Turbos, found a split vacuum hose going to the factory boost gauge sender, which I have since replaced.  Also found another leak on the gasket coming off the rear turbo outlet, have also replaced this. After fixing both of these leaks - still have the running rich issue. I’ve also tried another pair of AFM’s - no change here After pulling off the front turbo intake pipes, there is obvious shaft play in the front turbo, which now hisses loudly on light revvs although I can’t see why this would make the car run funny even under idle. I’m curious to know why it’s running rich before I potentially replace/rebuild turbos. The car is completely stock <50,000kms  other than an exhaust. Oil and coolant are all clear. I haven’t bothered with coil packs as it looks like they won’t be the issue due to condition of the plugs. Any help appreciated as I cry myself to sleep!
    • No probs at all. I used to love trying to dig up obscure info for those in need where possible going back 20+ years on SAU.  I did have another look and couldn't come up with any closer match. I'm leaning towards those skirts in your first pic are custom fitments, cut down/extended or from another car entirely and modded to fit an R34 sedan. I would've thought someone in Japan had them and taken a photo at some stage over the last 2 decades but there's nothing. Someone out there must know surely.
    • Welcome mate. Any pics? Even with a DE I'd be well happy if I had that as a 1st car.
