the only people who'd be envious of your R32 are 4 year olds on tricycles cos you have 1 more wheel than them. However even they don't need their mum to supervise em while driving, so I'm sure they too wouldn't be envious of your shit.
i actually agree.. its an old r32 taxi haha
whats to envy
i was thinking of buying a front pipe for the gtr but im not sure now because the stock one doesnt look that much different to the aftermarket ones, plus they say that the dump pipes are good in the r34gtr so i dont have to worry about that either. maybe i should just get an aftermarket ecu instead.
R34 GTR Dump Pipes will be fine, but I'd change the front pipes (get a full / turbo back exhaust).
I did on my R32 GTR and the exhaust flow is so much better.
You could do ECU, but if you don't have any extensive mods, it's not much point as the stock ECU can handle what it is doing.
ive already got the catback and got a new cat ready to be put in. but after looking at pics of a stock r34 gtr front pipe and aftermarket ones i dont see much difference and the sizing doesnt look small either so i just dont see much of a gain for the price of these things. so i thought id just put it towards an ecu instead and help with the very rich tune it has. but if anyone knows better with r34gtr's and there front pipes and what i should do id like to hear from them :P
get a blow of valve that goes sututututu
it. gets. bitches
you have no clue
im not after bitches im looking for broad minded persons.
edit: ok it doesnt let me say s-l-u-t-s
sluts
uras kit acquired.
thought you were selling?
go to any club on a friday or saturday night
you have no clue
being sarcastic mannn
sluts
ahahah i know the secret!
    • Jack the back of the car up, pull that wheel off, pull that sensor out, and put a bore scope into the hole to inspect the outer casing, see if anything looks damaged before you pull the whole thing apart.
    • Ergh... So I pulled the speed sensor out again and the tip was shiny so I think it's rubbing the bearing. The bearing contains the magnets for the speed sensor so I think when the first sensor broke it damaged the magnet ring on the bearing.  This is just a Google image, but there is a hole going to the bearing. So when the tip broke off the old sensor I'm guessing it fouled the bearing... As the magnet is only protected by a plastic cover it would be easy to damage it. So I guess I'm doing a bearing again.
    • My thinking is that if the O2 sensor is shot then your entire above described experience is pure placebo.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
