most S14's do nothing for me, but I spotted one one the way to school a few weeks back that looked sick...had gay plates 'DAGURU' but the car itself looked the goods...still not a fan of the rear of them but the rest was tasty...Was the dark purple-ish color with some fat TE37's
if anyones got any decent photos of it post em up
yes mohsen, thats the joke. thanks guy.
lol
fail
lol
edit: going cq tonight. anyone frequent that place?
also, are the trim pieces where the tweeters go on r32s, the ones behind the side mirrors, the same in coupes and sedans?
Edited by Mohsen
s14 on 7 series wheels. a reverse funky
For some reason i actually think its looks pretty good...surprised with the guy who done it and pulled it off as a decent lookn car...
I want roof racks for me gtr :D
ok ill buy front pipes first than ecu later on down the track :D
:P
You shall be happy with it!
does anyone else agree the chick from scrubs is hot?
You talking about Elliot Reid and Carla Espinosa..?
anyone got a photo of JDM145?
A S15 with a S14 front?
any spoked wheel with slight concave on an s14 with rails on the floor will look good. bros in oz just don't have the testicular fortitude to rock it.
instead they homo it up by putting cheap shitty URAS kits on their cars and think they're instant drift superstars.
guys in japan have been putting Infiniti FX 4WD wheels on 350z's, skylines and silvias for the last 3 years or so. 19" or 20" + same PCD + perfect fitment for an OEM finish. combined with low it's instant win.
Where do i find it? is it in Sport or Entertainment? Im excited, should be good!!
i think the channel starts in november.
with my new cat that i got it has the sensor hole, should i block it before i install it or doesnt it really matter?
yayyy... got my tax return.
time to drop some cash on 240z mods out of the US while it's cheap as shit
http://www.arizonazcar.com/TRACK-PAK.html
by the time I'm done with this car it'd be the metaphorical equivalent of climbing up on the table and taking a massive dump in australian zed owners' cornflakes.
also...
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
