fuck you. they're both cheap shitty knockoff wheels regardless of where your high and mighty ass wants to source them from. you wanna pull the material tolerance engineering card, fuck your ghetto ass, go get some TE37's and do it right. Don't try and validate your ghettoness.
Uras and Driteks can both suck on my nutts.
i lol'd
-____-
learn your wheels you dropkick.
Drifteks are multi-stud and have less aggresive angle on the spokes.
Uras are 5 stud, look much better and a japanese company.
well im sorry if drift teks are copies of uras and happen to look very similar mr road legal track car that never gets busted
edit: f**k im late lol
Edited by Mohsen
lol that attempt at an insult is so off the mark, you got no clue boy. Go back to studying for your exams.
Best be mindful which side your sitting on boy, cause last time I checked im one of the remaining r32's floating around on these pages. Would be a shame once your lemon starts to play up.
I have a spare ignitor module sitting infront of me now, might chuck it in the bin.
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
    • Why are you so adamant on going M12? Why not follow Brad (GTSBoy) suggestion. You're talking moving from a 1/8" size, to a 1/2" effectively. 4 times bigger. Why skip the commonly available sizes in between? The bigger you go, the more likely you are to strip the threads out at a later date, as guaranteed, someone will put a huge spanner on the M12 and really tighten it up, and you're only in thin wall, so not a lot of threads to engage!
    • Hi. Yeah thanks. Car is already at tuners and it staying there to resolve "many" issues they do not like. So it is in a good hands. Getting a good tune on that Nistune ECU too so the car would be good. Just needs a little tune up and love.
    • Probably gonna remove manifold and turbo. I’m not sure if I can get M12 x 1.5 air tight. Could use high temp Loctite 246 or something similar, but I don’t know. Maybe it’s just best to remove everything again and weld an 1/8NPT on there instead.
    • Yeah, saw the ratios, not impressed. Would like the punch I have in the first gears now. With those ratios it won't be the same.  Also want the h pattern gearing, or at least a quiet gear set that don't need to come apart for service each year. Looks like the only "reasonable" way Is a 8hp70 transmission, but where is the fun in that🤷‍♂️
