bought swaybars for the evo, sent it to the guy that ships stuff from the US to AUS
only costed $165 shipped for front and back
only problem is the container wont leave till middle of jan next year..... itll be a late xmas present for myself :D
waddup everyone got a question
anyone good with coils, theres a set of hks hyper d coilovers for sale for $400(really negotiabe tho) , rears are said to be fine, but front passenger coil is knocking/leaking.
you rekon its fine to run coilovers in rear and standard springs in the front, then eventually get some for front, but will prob be diff brand unless i get them fixed.?
Edited by blk_sz
if you really want them grab thema dn wait till you buy fronts
however if its a budget your on buy bc/br..... do they do them for chasers?
cause they fairly cheap, have a 1 year warranty and rebuildable
only problem is the container wont leave till middle of jan next year..... itll be a late xmas present for myself :(
your wheels going to be on that boat too?
hey guys..how easy to to take the immoboliser out of the car...is it like a black box looking thing you can just disconect? let me know my daily is stuffed...thnx...any link for info how to do this will be appreciated... :(
well i am stuck and my commodore is leaving me stranded in randomly wherever i park.. :blush:
it either starts healthy or it just doesnt for an hr....waiting in a car park for an hr waiting for the immoboliser to turn off so i can start is really getting to me now...
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
