Poor turnout for the Show n Shine, was there for about 20min... I vote my car for the loudest, Jamie heard me driving down the main road haha.
Where did you get yours made up?
What material is it made of?
lol you guys are gonna get pinned like eeeeeeeeeeeeervy day
Full stainless, hiflow cat only :P I rarely drive anywhere, only to work, which is a 10minute drive
Who did the exhaust?
PM me if you prefer, I'd like to have twin stainless steel and fix my twin muffler while I'm at it.
decat mang... mine is a cat shell with the ends cut off and a 3" pipe through it.
cant possibly get fine for it as it 100% looks the same as a cat
have heard of them using a temperature gun to see if its a real cat or not. also doesnt it sound hollow when tapped compared to a normal cat?
with the pipe welded into a shell it doesn't sound hollow.
if they hit it with a temp gun the best they could ascertain is that it's a cat that has broken over time and give an EPA - to which you would NEVER turn up to with the decat.
they can't actually PROVE anything....
of course there are about 600 other things they could pick on.... lol
yeh but it could be a f**ked cat.... they cant prove you were intentionally running without a working cat unless they drop it....
although, the way labour is running this state i wouldn't be surprised if vicpol will be issued with toolkits soon
either way that is pretty much a thing of the past now as a copper can just tick a box on a NOU that epa's you, and ANY car can be given an NOU without much hassle so they don't need to bother checking things like that.
    • LOL, all of the CAI like Craig I just need to put a hole saw through my bumper Done and dusted, the car runs, which is nice, I'll take it for a spin when the weather clears up Just need to put the bumper back on for good
    • Brooooo Please send ABS control unit schematic Please! R33 gts25t ABS (Its two plug ecu, black and white) wire colors possible? [email protected]
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
