Poor turnout for the Show n Shine, was there for about 20min... I vote my car for the loudest, Jamie heard me driving down the main road haha.
Where did you get yours made up?
What material is it made of?
lol you guys are gonna get pinned like eeeeeeeeeeeeervy day
Full stainless, hiflow cat only :P I rarely drive anywhere, only to work, which is a 10minute drive
Who did the exhaust?
PM me if you prefer, I'd like to have twin stainless steel and fix my twin muffler while I'm at it.
decat mang... mine is a cat shell with the ends cut off and a 3" pipe through it.
cant possibly get fine for it as it 100% looks the same as a cat
have heard of them using a temperature gun to see if its a real cat or not. also doesnt it sound hollow when tapped compared to a normal cat?
with the pipe welded into a shell it doesn't sound hollow.
if they hit it with a temp gun the best they could ascertain is that it's a cat that has broken over time and give an EPA - to which you would NEVER turn up to with the decat.
they can't actually PROVE anything....
of course there are about 600 other things they could pick on.... lol
yeh but it could be a f**ked cat.... they cant prove you were intentionally running without a working cat unless they drop it....
although, the way labour is running this state i wouldn't be surprised if vicpol will be issued with toolkits soon
either way that is pretty much a thing of the past now as a copper can just tick a box on a NOU that epa's you, and ANY car can be given an NOU without much hassle so they don't need to bother checking things like that.
    • Possibly avoid using a Cometic one unless the deck/head surface are perfectly flat. I did have a look just then and forgiving gaskets such as Tomei or Nitto don't exist for the FJ20, however the Bar-Tek or Kameari ones look good and might do the trick.
    • Because pipe threads for pipe things. M threads for bolt things. Throw some teflon sealant onto it and dust your hands off knowing you did the right thing, instead of going twice around the block to achieve a result using the wrong things. Of course, all of these solutions are ignoring the fact that the minimum thread pitch we're talking about here is 1.25mm, with the 1/4" in NPT or BPS being out around 1.4mm. You will need to know that the boss you're tapping has enough thickness for at least a few threads. That's one of the reasons that 1/8" is commonly used - because the pitch is <1mm. And why would you look to use 1/4" NPT in a BSP country anyway? Ugh.
    • Just throwing around ideas, does it need to be in the compressor cover? Why not the hot side piping?
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
