Poor turnout for the Show n Shine, was there for about 20min... I vote my car for the loudest, Jamie heard me driving down the main road haha.
Where did you get yours made up?
What material is it made of?
lol you guys are gonna get pinned like eeeeeeeeeeeeervy day
Full stainless, hiflow cat only :P I rarely drive anywhere, only to work, which is a 10minute drive
Who did the exhaust?
PM me if you prefer, I'd like to have twin stainless steel and fix my twin muffler while I'm at it.
decat mang... mine is a cat shell with the ends cut off and a 3" pipe through it.
cant possibly get fine for it as it 100% looks the same as a cat
have heard of them using a temperature gun to see if its a real cat or not. also doesnt it sound hollow when tapped compared to a normal cat?
with the pipe welded into a shell it doesn't sound hollow.
if they hit it with a temp gun the best they could ascertain is that it's a cat that has broken over time and give an EPA - to which you would NEVER turn up to with the decat.
they can't actually PROVE anything....
of course there are about 600 other things they could pick on.... lol
yeh but it could be a f**ked cat.... they cant prove you were intentionally running without a working cat unless they drop it....
although, the way labour is running this state i wouldn't be surprised if vicpol will be issued with toolkits soon
either way that is pretty much a thing of the past now as a copper can just tick a box on a NOU that epa's you, and ANY car can be given an NOU without much hassle so they don't need to bother checking things like that.
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
