Foxtel is a joke these days. The whole idea of pay tv is that there's no need for ads as you're paying for them
to run it... When we first got it back in the day ads were about 10 seconds long and only advertised the next show, but these days they're advertising products and run as long as, if not longer than free to air ads.
Yeah back in the day of the square black remote with rectangular buttons (anyone remember the "flip" button instead of "back"?), the only ads you got were for the show coming up next or on the same channel. Then it progressed to advertising inter-channel, but no commercial advertisements, but now we have free to air style shit...fucking brand power and all that jazz. It's garbage. I manage though...don't watch much TV, but when I do the ad breaks are to make food/drink and dispose of it :D
And yes Hamish you pay for more channels but one of Foxtel's slogans used to brag about no ads, and it was definitely a core selling point for their product. It's just that Foxtel having a monopoly on the pay TV these days, is a case of...we can do what we like...suck it up princess...they know you have no choice unless you wanna shoot yourself in the foot and cancel your subscription - then you're stuck with the same bullshit on free to air and alot less channels.
Mohsen, what have you done to get a thread against you?
- http://www.skylinesaustralia.com/forums/Pr...56#entry5550356
marc said rb20's are crap
so i said dead hookers are better than his wife :D
i just cracked up when i opened that, uncle looked at me like wtf
So my fuel tank is full of all sorts of shit according to mechanic. Bad batch of fuel has killed the near new walbro fuel pump so now the whole tank has to come out and be sent off for cleaning, and a new pump. Epic FML.
I see.
Bike boy from Gympie, has retaliated but in a non personal direct attack by using his missus username as the OP.
Or was it really her..?
LOL!
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
