fark what a random night, had 1 guy speaking to me about sussing out a r33 gts for 4'500, im thinking wtf is wrong wit it. shows me the link and turns out to be my old car which was written off with hail damage in march :) happy knowing its still around, was mint condition cept for hail damge. still got few things on it + same plates
stripped back to stock before it left me
http://www.carsales.com.au/all-cars/privat...id=12B5062CC0CD
