sif, GTR's are slow as shit compared to a Lotus Elise, which you should be able to find for about 25K for an old one.
Or an FD RX7
Most lancer Evo's VII's
also, half you fuck-knuckles passing judgement on style is hilarious. all y'all other than alex, blags n hamish can lick my nuts with your opinions. space invaders (thanks for the correction) headlining has been ordered for the golf.
:ermm: Damn straight my opinion matters!
On another note, Misses is buying me Carbon Ganadors for Christmas! What a awesome girlfriend!!! haha :P
omg, half my childhood was wasted on NBA jam.
my skyline wasnt that bad, neither is the evo i dont think
I think someones stolen funky and it's an impostor posting.
PS. I never claimed to be an authority on style. Look at my 3 cars ffs, quite simply all of them are confused, but that's okay with me.
mmm tempted to clear coat my wheels and chuck a big bag of dark green metallic flakes in it..... or maybe hot pink
want something to contrast againt the yellow
http://cgi.ebay.com.au/HOT-PINK-METAL-FLAK...=item53e4729675
http://cgi.ebay.com.au/DARK-GREEN-METAL-FL...=item53e2fe7953
You cant post that after having just tried to tell Shan your cars weren't/aren't gay
You wouldn't do it, too scared! Haha I'm always encouraging people to do whatever the f**k they want. I say go for it!!
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
