for an every day plod around car and for general usage - ie dont care 4 doors, big boot, towbar etc
subaru b4 auto or manual do you reckon
both are pretty cheap (auto or manual)
and we can both drive manual my 33 is manual and her swift is manual
would the auto be too pissweak given its only a 4cyl 2.0 twin turbo?
Work nuts :(
i thought so but for some reason i remembered them being internal drive...
i want to get some fairly long nuts, so i was thinking maybe Kics R40 Revo with red end caps.... not sure on the neochrome as yet tho
I'll post a pic of my neochrome r40's when I get home. They're the bomb, look so good :(
ah the misses really wants a wagon
looks like its the subaru legacy then
only a few for sale
but still wagon, twin turbo auto or manual
stagea went good. didnt look as ugly as legnum. 260rs are pretty cheap these days. get one with out any rust and your pretty set
we had a look at some models and i think were more keen on a newer wagon
so i think an n/a penis fuel wagon will be more suitable
i do love the legnum twin turbo 3 litre but i thnk maybe a mid 2000 ish outback or liberty
do u think there is any interest in the HKS Fcon range of ecu's
ive been given some pdf's, access to the software and cable etc and manuals
it's a shame there isnt much info on these beasts, they look pretty complex
mm the hks standalone FCON pro is 1600 and the hks FCON is piggyback with harness is 1160
the hand controller fcon navigator looks pretty small and is another 330
you can see why powerfc dominated already
its 900 with a complete stande alone solution and hand controller included
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
