never had insurance :/
i rang up a couple companies when i first bought the car 3 years ago, after checking my records and type of car it was they said they wont insure it for me and that was it. never bothered with it again
dood do you fkn realise how stupid that is?
what happens if you write off a roller? or even just a newish merc/beemer
He probably thinks he is too good to have an accident.
Another thing is if someone hits you who doesn't have insurance and writes off your car. Good luck getting a cent lol
Cars don't impress girls worth impressing. It may score you a bj or hj from time to time however.
im pretty sure shes just sucking up..
this the one that got a 25% enter and tried her very best
Lol have to get stock solenoid. If u just disconnect and connect lines it will run unlimited boost
lol thought so, hrms
wtb, stock rb20 solenoid
wtf are you two on about.
The r32 does not have a boost solenoid. Only the r33 does.
Pull out the bleed valve and reconnect the hose. Not rocket science.
A single hose from the actuator to the turbo. Done.
Epic lol if you posted up a WTB thread for a r32 boost solenoid. May as well ask for headlight fluid.
Lol well I down a piece of shit r32 so I assumed it's got a solenoid. Chill princess Tricia
just had a stupid holden ute tail gate me then overtook me and got stuck behind a car infront and instead of waiting for the overtaking lane that was 50m ahead he pulled out over straight lines and sprayed rocks all over my car so i quickly floored it to catch up so i could get his number plate and abuse him just incase if my car got any big stone chips from it :angry: he shouldnt be hard to find he has personalised number plates and live in the same area as me. can you seriously get anymore impatiant than that?
    • Initially I thought having a pair of Recaro seats would be a big bonus, it turns out these do get a little uncomfortable on long journeys (my fault, not the seat). I had a look through the GSM Performance website at reclining seats and booked an appointment to visit their show room. I got the Recaro Sportster CS for the R34 from here, was very happy with the service received so of course a re-visit was in order. Unfortunately the two Corbeau seats I had chosen aren't on display but they had 4 other options available. Two seats dug into my back, one dug into my legs and the other was perfect. I also found out that Recaro seats use a larger bolt pattern so some adaption was required. Luckily GSM offer some universal adaptors that should solve this problem. I searched the interwebs for price comparisons and Corbeau themselves were the cheapest at £300 cheaper (for the pair). I asked GSM if they could price match, unfortunately they couldn't. I later received an email saying Corbeau would honour them the same discount, but the purchase was already made. I did however order the brackets from GSM, both arrived on the same day. I started with the passenger side seat, knowing this was going to be a little trial and error. There are 3 mounting holes at the front and 2 at the rear on these JURAN Racing seat rails.  With the adaptor brackets mounted, the allen cap bolts started to push into the seat, NOT GOOD!  The rear mounting holes lined up but there were issues at the front. The holes were 1/2 hole out, so the brackets got a tickle with the drill to modify the holes. The supplied bolts weren't going to be long enough and a spacer was needed to stop the adaptor bars from bending. A local fasteners company supplied be with some nylon spacers and longer bolts (M8x30, although these will be replaced with 35mm long shortly) A before and after I pre-drilled the front bracket before making a start on the driver's seat to save some time. And in no time at all that was in the car too. The all black seats have transformed the interior and these are MUCH more comfortable. The only downside with the new Corbeau seats is I sit a little higher, but I'll happily accept that over discomfort. The Youtube video can be found here: https://www.youtube.com/watch?v=wPyttKPktXA
    • All 3 I guess. The car came with the JASI Aero 4 door Type R Full Kit unpainted so this was one thing at the top of my list to complete then I noticed there were body panels parts for this kit so i picked them up along with some black mesh to fill in the front bumper and front side air vents. car is at a paint and body shop atm completing this work. Next I will be addressing the internal bells and whistles, great summer project I can do with the kids.  full interior removal - ,boys car sound deadening - pads and spray ,boys stereo, sound, lighting - Big 3, GTT or bigger alternator ,kids head lining - dye black add star lighting mod ,daughter. That's it for the next 5-6 months. I have some motor maintenance  work i have to plan out. oil filter relocation, gaskets, mounts. beyond that, mind is starting to turn over if i can use a DET intake plenum, block off turbo ports & pipe in a air intake.
    • roller coaster of a ride. Alarm system was removed & main harness was repaired where possible. still no fix just random successful starts. moved on to the replacing the ignition switch and relay. well all this troubleshooting & repair has been going on, the car is at a paint and body shop being pushed around. Ive been going down there on odd days after work to get it sorted.
    • 5th November if you want to come out for a spin wakfield
    • PROBLEM WAS BROKEN COOLANT SENSOR!!! Replaced with a new one and its running mint.
