what are some good brake pads for street use and a weekly "mountain run" ? without spending a fortune...
oi Grant re: red recaros, got pics? how much for just 1 without rail?
QFM HPX, under $100 for a pair. Trader on forum.
Do not recommend for track work. Glazed them after a couple of laps
Don't get the QFM A1RM pads either. Mine screech so bad i'm considering getting rid of them. There are much better options out there i'm sure.
not a good pad for daily. Killed my brand new rotors in 30,000km. They squeal because they arent up to operating temps and eat through the rotors really badly. I did fix the squealing during regular driving by properly bedding them in on the freeway.
  • Like 1
wtf are you two on about.
The r32 does not have a boost solenoid. Only the r33 does.
Pull out the bleed valve and reconnect the hose. Not rocket science.
A single hose from the actuator to the turbo. Done.
Epic lol if you posted up a WTB thread for a r32 boost solenoid. May as well ask for headlight fluid.
noted
lol @ headlight fluid
and, jeeeezzzz you and kris really love going at it.. arguing like a married couple and shit
Does anybody know if a rear strut brace will do anything on an r33? I've heard them make feck all difference.
have you already upgraded your swaybars? They do the most in handling. Best bang for buck for handling.
You will definitely notice a difference with new swaybars.
internet is serious business
lol homos
top gear causes outrage among muslims
seriously, the syrian doods that saw them when they rocked up in the curtains just had a laugh.. no idea why those bearded f**k tards think its so bad
Yes, this is true. You basically have to bed them in every week which is a pain in the arse.
Swaybars are next on my to-do list. I really wanna upgrade some of the bushes as well because I like the idea of a car that feels really tight, like its just rolled out of the factory. Do you have any suggestions on what I could do to achieve this?
lol homos
LOL that was a fkn pissa. meh cant please everyone, lighten the f**k up and laugh.
just start replacing the bushes with adjustable ones. ie. front/rear camber, castor, power steering rack bushes, subframe locking bushes. Bundle that with some swaybars and a decent wheel alignment and car will be handling like its on rails
Id get swaybars first, see how the car feels/handles and then start replacing bushes (if needed)
Thanks mate, I'll be getting my rental bond back soon, so it will be time to do some shopping ; )
How much would I be looking at for those bushes as mentioned?
have a look at project mu brake pads, i went with the b-spec ones in my old car and loved them.
i'll look through traders on here see what they've got
not selling separately, sorry
rude
ive got bendix ultimates i think in my gtst and they work ace
no issues with heat or normal street driving
i think i've got bendix on my car atm but dont think they're ultimates
    • So could it be assumed it has been installed intentionally with potentially a power FC boost controller kit?
    • Had my rig on Matt's dyno at PITS the other day. After a few years between tunes I added a few sensors and swapped intercoolers. Result. 553hp at 26psi. Not bad for an FJ20 that was built in 2007. The problem.. It filled the overflow bottle on hard runs which leads me to believe the head gasket isn't sealing. I have a coolant pressure sensor which was reading cap pressure at 22psi and occasionally overrunning to 23/24 psi on deceleration after a pull. It was not spiking. It has arp2000 head studs and a cometic gasket. As its been 18 years in service, I pulled the engine out and head off. Everything looks good but we obviously have an issue. Where I'm at.. Years ago I had the same issue, I checked the stud tension and they were all over the place. Some at 60 to 70 and some up near 90. I nipped them all to 100ft lbs and this stopped the water push until now. I believe this compromised the gasket back then. What do I do? 2 options are..  1) I bought arp 625+s, which I could put in with a new gasket. Thinking Kameari this time, reassemble and try again. 2) strip the block, get fire rings machined in with copper gasket and try that. I do not want to push it more than 28 to 30psi. I think the turbo will be out by then anyway. (G30-770). My other concern is the long term ability of a copper head gasket. Are they streetable for years? I feel like a new gasket with the new studs will probably suffice, but I don't know. Any thoughts welcome and advice on copper gaskets and fire rings. Thanks!
    • I'm a fan of the JZX110, and the Aristo. Big cruiser cars, and with the factory cars, super comfortable and feel like you're driving an armchair! And the JZ motors are a pretty nice engine too, especially with some basic mods.   The import process, and the need to be able to trust people, and the fact there's so many scammers around is what ever puts me off wanting to go through that ordeal!
    • I don't care for these at all, but at least the underside looks straight and not rusty. A good basis for a long life. Many cars from Japan have been lifted with forklifts and f**ked almost irrepairably.
    • Yes, but it's not dumb or dodgy. You can build a perfectly good boost controller from a pressure reg, a relief valve (looks same same as a reg if all from Norgren or SMC, for example) and a check valve. I ran one for years. Only superceded with  EBC because I could get one for cheaps and wanted finer control.   THis mod is certainly not a sketchy boost mod, provided the boost is kept below the "spin to death" threshold of the turbos.
