http://soundcloud.co...1-free-download
A mates mix if anyone wants to listen to it, just helping him get his name out a bit cos his good
Not bad :) Transitions could be better though.
Getting a better deal than me :P given your age and how new the car is that's all in order. But FFS if u buy a BMW get insured with someone else. JCI charge thru the teeth then rape u for excess once u make a claim. Trust me. If anyone else would insure my gtr I'd jump ship quicker than a rat off the titanic.
$630 for ze golf. $650 for the R32 when I had it. $430 for the 240z, but that's cos it's insured as a classic show/track only use car.
All with shannons on a rating 1.
ok hang on so the $2802 is what i pay per year and the "excess" which is $1600 is what i pay in an event of an accident etc? 3046 much safer than 3047 :P
what do yous pay then for your premiums?
3k
my is250 is with JCI its a very good deal and im under 25 the premium/excess is very fair, excess as opposed to how much agreed value, i just wish someone would write it off for me. I've had an at fault claim and a not at fault claim they were really good for both
I've had both too. The only time they've been half decent has been for my 'at fault'- which theyve tarred me with because of the pothole drama. I'm at fault for a hole in the road... Ok...
I pay 3k p/yr comprehensive, I'm 22, and my excess is 2-2.5 k...
But most of all when I've had to deal with them they've treated me like crap.
not many places will touch imports either. altho M3 isn't an import so you can get it from anyone, not just JCI. isn't there a website you can compare all the insurance shit on? chuck it in one of those.
    • The attached document is fine. I just downloaded & opened it.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
