be careful, ebay Exedy's aren't all legit. we had an Exedy rep come in after some dude brought in a car that had shattered its pressure plate, to be told that it was a replica or someshit.
anyone know much about macs in here
got a mac desktop about 1 yr old i think
turn it on, it boots up to a white screen with "FILE" in the middle and does nothing else
it reported some error the other day, the owner doesnt remember what it said
and it was working fine, then came home to locked up mac, rebooted it and it boots to white screen with "FILE" in the middle
im guessing toast hdd ? any other ideas or tricks ?
Oh its a Mac?
May I suggest a large Hammer, maybe 18-20oz or so and see if that fixes the problem
if it's a mac running OSX 10, then press f8 during boot at the white screen, use the help command to find what boot switches you can use. verbose boot usually tells you where it's falling over.
it's exactly like unix, same diagnostic procedure.
Shutup.
I'm coming to the charity cruise in an ml320 lol
make sure you don't roll it by trying to drive it while you fish the tabouleh out of your bumbag.
What's funny about that?
They're wasting their time braking to check it out?
Gold
It's turbo alex.. Had a few calls. All time wasters asking if I wanna swap for their commos
Check the price on ebay... then head over to your closest Supercheap Auto/Autobarnz and they should be able to price beat ;)
which would be a great idea if we pricematched with the Internet. Cept we don't.
Price matching applies to local business only. And part must be identical.
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
