be careful, ebay Exedy's aren't all legit. we had an Exedy rep come in after some dude brought in a car that had shattered its pressure plate, to be told that it was a replica or someshit.
anyone know much about macs in here
got a mac desktop about 1 yr old i think
turn it on, it boots up to a white screen with "FILE" in the middle and does nothing else
it reported some error the other day, the owner doesnt remember what it said
and it was working fine, then came home to locked up mac, rebooted it and it boots to white screen with "FILE" in the middle
im guessing toast hdd ? any other ideas or tricks ?
Oh its a Mac?
May I suggest a large Hammer, maybe 18-20oz or so and see if that fixes the problem
if it's a mac running OSX 10, then press f8 during boot at the white screen, use the help command to find what boot switches you can use. verbose boot usually tells you where it's falling over.
it's exactly like unix, same diagnostic procedure.
Shutup.
I'm coming to the charity cruise in an ml320 lol
make sure you don't roll it by trying to drive it while you fish the tabouleh out of your bumbag.
What's funny about that?
They're wasting their time braking to check it out?
Gold
It's turbo alex.. Had a few calls. All time wasters asking if I wanna swap for their commos
Check the price on ebay... then head over to your closest Supercheap Auto/Autobarnz and they should be able to price beat ;)
which would be a great idea if we pricematched with the Internet. Cept we don't.
Price matching applies to local business only. And part must be identical.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
