Haha toxic farts over here too. Since I've been on my high protein diet (7 meals a day, up to 3 protein shakes) I've been going off tap. EVERYONE is suffering.
Edited by jezza boii
Thanks mang :)
Awesome photos Jamie, not sure if they're hi-res because I'm looking on my phone but Can you send me hi-res Pleaseeeeee :) [email protected]
No worries Billy!
Check your Inbox.
yay corona goes in to get a new brake master cyl tomorrow, then the daily will be A1 condition woo woo then I can start pouring money into the GTR
GTR is only gonna cost you $200 to fix :laugh:
As you have said...
Nah man more like $200 for the bushes + $300 labour to get it done coz ceebs doing it myself and the corona is $310 for the master cyl at trade price then another $90 for labour and fluids ect ect
so like almost 1k right there.
Ok so for this week, spend $400.
Space yourself out another week or 2, to get some funds and spend $500 on GTR.
Done.
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
