No, just stops the needle from going anywhere :)
That's a shit fix
michael- nope, thats a proper arab accent.. i think i talk a bit like that too, though alot of people say i sound like a normal person( not a habib from thomo LOL)
RIMON- why wouldnt you! siff your tayta hasnt gone into your room and packed half your bags with random shit ..
Tayta?
I paid for all of my cars in cash.
My pet hate is when people's parents shell out ridiculous for their kids cars, I.e.new Mini Cooper / BMW etc. I'm working in Hawthorn atm and i see it everywhere. Little red p plate arseholes can go and f**k themselves.
If your parents offered you a sweet car, you'd take it. So quit bitching.
Saw a dude on red Ps with an e46 m3 the other day; mates see him all the time so it must be his. Douche
Despite fearing the atomic wedgie I may receive from my fellow skyliners, I have to ask:
What is this 'engine out' business? I must have missed the initial discussion where the term was coined because I'm not sure what it means? Would someone kindly explain?
i don't like that attitude, only cos i was on p's with a 40k car and my parents didn't pay for shit people are to quick to assume, i use to always cop that shit and even still cos i look kinda young if im just in casual clothes etc i cop funny looks. Especially in trackies jumping out of my lexus, dealing much :laugh:
Fair enough mate, I never thought about it that way to be honest.
You're right, people are quick to assume (me included).
I am a massive R32 sedan addict (I have 3) but I have to say R33 series 2 sedans are pimpalicious.
In other news I cleaned AAC, AFM, Air Regulator, replaced vacuum lines, removed horrific boost gauge vacuum lines, replaced PCV hoses that were rooted, reset ECU.. and now the RB20 is running like a dream :D. One of those things you kick yourself for not doing sooner.
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
