SE pre meet posted in the charity cruise thread! Hopefully see some of you guys there (the ones that aren't whinging about it being too far)
I might rock up at pre meet and chill for a bit, iuno see what i feel like at the time getting wasted or cruising
I know!! Always annoying to have to pick one only not both.. I just need a driver, then I'll be set!
That sounds like a good idea! although sitting in the back of a skyline wasted through twistys might be weird :cheers:
that mr2 / ferari abortion needs intercooler mesh then it would be set
die hard 3 ripped to 1.6GB 720, good work auto GK
much better than f**ken xilisoft
I Forgot I burnt some HD movie for you - but never ended up posting it lol
$1100 for rb25 gearbox + custom 1pc tailshaft (for r32) + speedo sensor cog + mounts etc to fit r32 gtst
Or
$900 for rb20 gearbox rebuild when it blows....
Worth the whole hassle for a car which only puffs out 200kw? RB20 and Rb25 gearboxes can handle that power with no issues...
Dont need gearbox now so the $900 could be spent on other things like a diff or finally replace my jap headunit (after 5yrs) and get the 3 of the 4 speakers in the car working....
hrmmmmmzz
it's meh... untill you see the pic of the fake mid mount engine.... then it's :rofl:
cruise tomorrow is mt macedon -_- soooo far away lol thinking i might just get wasted instead
fkn at least come to the meet and pay some $$$.... it's for charity fag
Couldnt even pay me to drive that thing for 5mins. You can spot the fakeness a mile away. Disgusting.
no shit.... it even looks worse than a real fezza... and that's an effort!
Or
hrmmmmmzz
keep box... thrash hard... spend monies when broken
if you think it looks good because it's a ferarri, then you are truly an idiot...
NONE of that makes sense
edit: "you" meaning people in general... not rimon/dezz in particular ;)
Lowered, rota drift grids, orange.
Matching orange side mirrors (couldnt photoshop) and orange side-wings on black GT wing and orange n1 bootlip when no gt wing on.
17x9 +25 or 18x8.5 +25
Are you positively annoyed friend? cause im stylyn on you?
Note: Will be street use only. Track rims are for track, so no fear rotas wont be exploding on me :P
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
