Why baby blue stokers tho?
One day couple of years ago he was bored and decided to spray it with some spray can we had laying around and that's it
replace the wheels with some decent non ugly ones and it'd look good....
what's wrong with it mechanically?
Yeah, was umm and ahhing about getting work meister for it.
Currently there's a leak from somewhere and it need retune badly.
Body would need a respray but couple of friends suggested cut n polish but I don't think it'll work.
While you're here, may I ask how long did you have yours?
And have you done anything exciting to it?
I bought my GTR back in August 2005.
Changed new front disks and brake pads.
Rebuilt Rear Diff.
Rebuilt Turbos to steel internals.
New OEM Clutch put in cuz the HKS Twin Plate just about had it.
Aftermarket Front Pipes and a Highflow Cat put in... Also have a Cat Back oval shape muffler going on.
New OEM Slave Cylinder.
Did more rebuilding rather then modifying.
I can dump money in it for the "Go Fast Mods" but I know 1 thing leads to another as this car cost already, as it is.
It is lightly modded and good enough for my weekend drives :)
I say you should enjoy what you got there (your R32 GTR) as you know, the power bug has hit you and you will never be satisfied...
First it is 200+ kWs, then you want 300+ kWs and you will be chasing 400+ kWs... It never ends... Leaving a bigger hole in your wallet.
Lower your standard of your expectation for your car and you will enjoy it better.
Remember, you do have decent mods on it... Utilise it and enjoy it...
That's what I think anyway :D
scar non?
Landed at hamilton island at 12 then had to evac at 4pm :(
Ho hum :(
go to the shooting range and hire a golf buggy and try get air in it haha
Was only there for a day passing through to the barrier reef. How long you there for?
yeah we are still on holidays , just not on hamilton island. Yep 4 hours , landed at 1230 and got ferry off at 4pm. We had time to try and get flights out (no chance) and time for a quick walk around a few drinks and lunch
    • So, before putting them in I need to understand the stock ride height. This is how I measured it: First, check the diameter of the wheel's centre cap, it was 52mm. Then put a piece of masking tape approximately across the centre and measure 27mm (half) from at least 3 sides to get a reasonable idea of the centre of the wheel cap. Mark that with a horizontal line as one measuring point. Then, directly above the wheel on the guard, put another piece of masking tape in approximately the centre. Use a string line to find out the point on the guard above the centre of the wheel cap and mark that. Then it is simple, just a tape measure to check the distance from centre of the wheel to the centre of the guard. Final results where  LF: 381mm RF: 379mm LR: 401mm RR: 400mm Pretty even considering they are 120,000klm old factory springs, lets call that 380 front and 400 rear.
    • So....knowing that I have a problem with power steering temps on track and another Wakefield day booked in next Friday, I've done the obvious thing They are very reasonably priced at $1650, considering they are a big monotube shock, double height adjustable (don't have to change pre-load to change ride height), one way adjustable damping and standard sized and customisable springs if you want something other than what comes with them. They come with 9kg/mm front and 4.5kg/mm front and I went with that as a starting point because I'll add adjustable sway bars too https://justjap.com/products/bc-racing-coilover-kit-ds-ds-infiniti-q50-v37-14-current#description Unfortunately they didn't come with rear strut tops so I've re-used the factory ones which was a bit of a pain. Also, the adjuster for the rear shock will be an absolute nightmare to get at, and while there are extensions in the kit I can't see any way you can actually attach or use them
    • I also had 2 bulbs blow at once, years ago in the stagea. made for a fun drive home. The issue was the voltage regulator had failed in the alternator and it was giving 15+ volts. Really, I was lucky all that was fried were the headlight bulbs. So, I'd suggest you check the voltage across your battery terminals with the car running and warmed up. Yes, you will need a multimeter to do so, sorry.
    • Good work to think to check that, and thanks for coming back to post up the outcome.
    • Given it happened suddenly, and when you come on boost, I'd check all your inlet - hose clamps in place and no split rubber or silicone hoses. Even the hard to get to ones near the intercooler. It's possible air that went past the air flow meter is being dumped out a big hole.
