Haha I meant the opposite Cass! :P I was gonna have some ridiculous polished dish for events like Autosalon etc.
Wouldn't trust replicas for daily driving.
I'd buy stockies for track, or some kind of 15/16" wheel.
I bought my GTR back in August 2005.
Changed new front disks and brake pads.
Rebuilt Rear Diff.
Rebuilt Turbos to steel internals.
New OEM Clutch put in cuz the HKS Twin Plate just about had it.
Aftermarket Front Pipes and a Highflow Cat put in... Also have a Cat Back oval shape muffler going on.
New OEM Slave Cylinder.
Did more rebuilding rather then modifying.
I can dump money in it for the "Go Fast Mods" but I know 1 thing leads to another as this car cost already, as it is.
It is lightly modded and good enough for my weekend drives :)
I say you should enjoy what you got there (your R32 GTR) as you know, the power bug has hit you and you will never be satisfied...
First it is 200+ kWs, then you want 300+ kWs and you will be chasing 400+ kWs... It never ends... Leaving a bigger hole in your wallet.
Lower your standard of your expectation for your car and you will enjoy it better.
Remember, you do have decent mods on it... Utilise it and enjoy it...
That's what I think anyway :D
I'm curious as in why you're binning HKS twin for stock clutch.
I'm guessing you haven't raise the boost level and tune it correct?
no not really enjoying it as we have spent the whole time try to book other places and get out. Once we get past mackay then we will be fine and can resume holiday. Not much we can do hey
'just about had it' grant. Means it was broken.
As to his choice in replacement... *shrug*
I know, why stock, wouldn't sane person go something beefier or stock clutch are as good than people make them to be?
When I had 33R, the clutch didn't last, and I upgraded to OS Giken Triple plate.
Correct Cass! :)
Grant, the car came with a Twin Plate... Who knows how long it has been in there...
Judging by my "whining" rear diff (at the time), the Twin Plate would have seen a lot of 5000+ RPM launches.
It lasted me about 2 years of ownership and started to slip = car won't go anyware = had to rev the hell out of it just to hope it will grab to make the car go.
Pulled the Twin Plate out and there was burnt bits of clutch / ash... Flywheel had wear and tear as well.
Being a 1st time GTR owner at the time, didn't know much about the characteristics of driving with a Twin Plate as there is no play (well not much) it was either IN or OUT of gear and best driven for track use.
At the time it was a daily for me so I need a plate that was good for that...
So I decided to go with a single OEM plate as I know Nissan would have engineered it to put up with a 2.6lt, Inline 6 Twin Turbo.
Meaning it would have to be at least a heavy duty single plate clutch.
Geez, would hate to be on run from mother nature during holidays.
Queensland doesn't have much luck with weather lately...
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
    • Why are you so adamant on going M12? Why not follow Brad (GTSBoy) suggestion. You're talking moving from a 1/8" size, to a 1/2" effectively. 4 times bigger. Why skip the commonly available sizes in between? The bigger you go, the more likely you are to strip the threads out at a later date, as guaranteed, someone will put a huge spanner on the M12 and really tighten it up, and you're only in thin wall, so not a lot of threads to engage!
    • Hi. Yeah thanks. Car is already at tuners and it staying there to resolve "many" issues they do not like. So it is in a good hands. Getting a good tune on that Nistune ECU too so the car would be good. Just needs a little tune up and love.
    • Probably gonna remove manifold and turbo. I’m not sure if I can get M12 x 1.5 air tight. Could use high temp Loctite 246 or something similar, but I don’t know. Maybe it’s just best to remove everything again and weld an 1/8NPT on there instead.
    • Yeah, saw the ratios, not impressed. Would like the punch I have in the first gears now. With those ratios it won't be the same.  Also want the h pattern gearing, or at least a quiet gear set that don't need to come apart for service each year. Looks like the only "reasonable" way Is a 8hp70 transmission, but where is the fun in that🤷‍♂️
