http://www.skylinesaustralia.com/forums/topic/354115-want-to-buy/
wow.. op seems like the type that would stab you in the eye and then skull f**k you with a broom if you ever asked him if he needed help LOL
lol dude seems to have the right technique to ward off cock spankers like you.
that guy is showing more attitude in replies than your recent work Shan! Losing your game son! :nyaanyaa:
meh, there's only so many times you can yell at your retard kid before you decide it's time to load the shotgun.
re; house auctions.
If you win a house auction, is it pending finance approval? Or is the winning bid locked in and you forced to pay?
I know private sale of houses can be put on hold subject to finance, but is this the same for auctions?
cheers
nah you can bid, thats why they have a settlement date
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
