yeh unfortunately the industry is rife with duds, at least in a tougher market they get weeded out but we arent all like that i'd offer to show you some places but i spose you dont wanna be a westie ahahaha
like i said but let me know if i can help still trying to chase up the info you pm'd me havent had much luck if your looking at apartments at docklands i can get a guy who sells em new off plan and stuff there to help you maybe
haha westside for life!
nvm about the price chase up. The properties are in the past. Got new properties to deal with now haha
Lookin to secure something in St.Kilda / Elwood.
if you like bangs, you'll love R.A.E.D
http://www.youtube.com/watch?v=ddwmcnLJYks
[/quot
i thought that was so funnnyyyyyyy yeah. and ih was rolling on the floor laughiiiinn girl.:rofl2:
i love this city babbbbeeeeee 3.00 min mark best
didnt think anything was gonna top Eli Porter Vs Envy original.
check out remixes
sadly, they were probably some of his best lyrics
elwood... so it's either shithouse or too expensive....
lol
yeah... check out his other "works" from the same "album"
i cried for like 20 mins the first time i found out about him...
best bit is he's serious
He even spends actual money on his film clips...what is wrong with these dream boats
thought about moving further out for your first property mang?
elwood and st.kilda sell for similar prices. Depends how close it is into the city or to the beach or both.
mohsen was a douche and his car didn't sell
adam and i argued over well done steak
shan was virtually absent
paul posted movie qoutes
grant was indecisive over what car to buy
dezz talked about eating lots
  • Like 2
So a normal day at the office then.
why are u trying to buy in st kilda or elwood?
have you lost the plot? as a first house.... ?????
dude rent there instead and buy a shitter in another suburb and rent it out instead
sif buy there for your first house
Juliette, I can introduce yours into Armco barrier if you want?
Tomorrow night the GTR will be gone.
I'll try to beg my mum into giving me keys to her BMW for me to cruise in on Saturday, should be fun considering my 'reputation' on club events...
i gots a bid!
straight out gona hunt the bidder down if they are unresponsive.
Edited by Mohsen
    • So, before putting them in I need to understand the stock ride height. This is how I measured it: First, check the diameter of the wheel's centre cap, it was 52mm. Then put a piece of masking tape approximately across the centre and measure 27mm (half) from at least 3 sides to get a reasonable idea of the centre of the wheel cap. Mark that with a horizontal line as one measuring point. Then, directly above the wheel on the guard, put another piece of masking tape in approximately the centre. Use a string line to find out the point on the guard above the centre of the wheel cap and mark that. Then it is simple, just a tape measure to check the distance from centre of the wheel to the centre of the guard. Final results where  LF: 381mm RF: 379mm LR: 401mm RR: 400mm Pretty even considering they are 120,000klm old factory springs, lets call that 380 front and 400 rear.
    • So....knowing that I have a problem with power steering temps on track and another Wakefield day booked in next Friday, I've done the obvious thing They are very reasonably priced at $1650, considering they are a big monotube shock, double height adjustable (don't have to change pre-load to change ride height), one way adjustable damping and standard sized and customisable springs if you want something other than what comes with them. They come with 9kg/mm front and 4.5kg/mm front and I went with that as a starting point because I'll add adjustable sway bars too https://justjap.com/products/bc-racing-coilover-kit-ds-ds-infiniti-q50-v37-14-current#description Unfortunately they didn't come with rear strut tops so I've re-used the factory ones which was a bit of a pain. Also, the adjuster for the rear shock will be an absolute nightmare to get at, and while there are extensions in the kit I can't see any way you can actually attach or use them
    • I also had 2 bulbs blow at once, years ago in the stagea. made for a fun drive home. The issue was the voltage regulator had failed in the alternator and it was giving 15+ volts. Really, I was lucky all that was fried were the headlight bulbs. So, I'd suggest you check the voltage across your battery terminals with the car running and warmed up. Yes, you will need a multimeter to do so, sorry.
    • Good work to think to check that, and thanks for coming back to post up the outcome.
    • Given it happened suddenly, and when you come on boost, I'd check all your inlet - hose clamps in place and no split rubber or silicone hoses. Even the hard to get to ones near the intercooler. It's possible air that went past the air flow meter is being dumped out a big hole.
