why didnt you kill them? i would of in grand theft auto because i dont know the difference from reality and video games.
:rofl2:
oh and Cas I got a major in my old car for 2 things :s had to get a roadworthy no fine though
Hey guys, i need your help !
does anyone have an account for nissansilvia.com ??
it wont let me register for some reason and I'm really wanting to buy an advertised front bar for my 32. :ermm:
if anyone can help me out by using there account to leave the guy my number, would be much appreciated.
oh is that in the big frame to hold it up?
im only at 12.5kg squat
pissweak haha
Yeah in the squat rack, not in the smith machine with the guides on either side. 12.5kg sounds real low even for a beginner, but I'm guessing you're not including bar wright which will be at least 15kg, 20kg if its a full size bar
why do you need to go over 180km/h?
You will most likely fark up your hicas and sensitive steering if you chop the speed signal wire from the ecu. (basing this off r32)
I found out at Sandown my '34 had the speed limiter removed.
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
