why do you need to go over 180km/h?
You will most likely fark up your hicas and sensitive steering if you chop the speed signal wire from the ecu. (basing this off r32)
You reach 180 at Calder about 3/4 of the way down the Straight. The guy in the white 34 with gold bbs wheels (sorry dunno your name) was driving down the straight sitting on limiter lol and as for hicas, that's long gone, I have a lockbar.
cops got nothing better to do they may as well stick exhausts up there asses, my 4" cannon wont satisfy them I recon.
Billy how did you go any pics?
I've got stock ecu and looks like still has all the standard nissan wrapping and tape stuff as well and I can still get over 180 :D
Driving V8s at sandown tomorow :D
Me too.. Was so pumped for clubbing tonight. Got all the way to the city then my mate's car overheated. We got it going again but the mood was dead so just came home again at about 1.30 :( Epic fail of a night.
