i've got a mate that would pay 5 if you convert it to manual for him ;)
5300 as is no less
good price for a good car. you saw it hame, aside from the scratches on the front bar, its very clean :)
5300 as is no less
refuse to pay more than it was bought for. Cars do not equal profit!
  • Like 1
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
