Interested buyers loved the test drive in my car, spent 45 minutes going over it but have offered me $500 less than what I'm asking. They know I'm already asking a ridiculously low price for it and have gone away to think about it. They'll be back in two days offering what I'm asking, I know it :)
are you serious
are you delierious
http://cgi.ebay.com....=item4aa912aabb
**$1,000,000 listing is for advertising purposes only**
^^ Ad displays...
What ever that means...
Just put the asking price, I'd say...
dude gets guranteed views when people search on ebay, 99c listing price for ad, potentially serious buyers who'll play each other off etc. Plus he gets chumps like you guys talking about it and linking it in forums etc.
Sounds like he's got connections in japan etc, so I'm guessing if the bids go above 50k he'll make a profit regardless. Which from the looks of it, will happen.
you sent em away over $500 !?!? :domokun:
Yes. I agreed on a reduced price when before they came out to see it. They drove it, loved it, and couldn't fault it. They even said "you're asking a very fair price." They wanted me to knock a further $500 which is part of what they'll pay in transfer fee's. I'm sorry, but it's not my problem if they've never bought privately before and didn't realise there was fee's involved to get it into their name, I'm not footing the bill for it. If they go ahead and buy it I'll be up for about ~$500 to get it roadworthy as I promised I'd put brand new front tyres on it.
So yes, I sent them away over $500. My price is my price. They said they'll call me in two days. They liked it too much and have been searching for 2 years for a car like mine and have come across none in such good condition for the price. They'll be back.
I dont like people that come and look at your car for sale, and say they been looking for like a year its like nothing is good enough for them and they want to find a 100% perfect show room condition car from the 90s and expect the price to be the same as every other car.
Also don't like when you ask "looked at many cars?" And they respond by saying yeah - been looking at (insert 15 different cars here) its like they don't know what they want and just seems like a waste of time. This is only my personal experience though. Especially when some of the cars on the list are 10k and some are 50k + :whistling:
The car is perfect in their eyes, they're just trying to buy it at the same price as the crappy examples that are for sale with dodgy km's, dodgy owners and no doubt poor repairs. My car is original and honest. I already think I'm selling it too cheaply.
I even let their children climb through the car.
They'll be back.
just want to put it out there..
and everyone told me not to do this but i did it anyway
if you have a walkie stacker at work, dont stand on a trolley and kinda wheel around the factory in it. because you WILL forget about momentum and slam your chest into the fkn thing..
end stupid act admission/
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
