going by what you said, wont the Nissan Cube then cut into the market of Micras? (Tiidas arent made anymore) As I was saying, 15yr old skylines dont impact on any brand new cars Nissan sells whereas the Cube competes against Micras.
current gen micras are:
a) different target market
b) different chassis to the cube's currently being imported (K13 vs K12)
http://www.hyosung.com.au/road-bikes/gt650r-efi-2011/
Thoughts? LAMS approved 650, looks the sex for only 7k new.
I'm diggin it - booking in my bike learners.
(I've actually ridden bikes for 10 years but had to sell to buy the line)
I was hoping for a bigger kid to then flatten the fat kid, then a BIGGER kid comes and flattens HIM, then an EVEN BIGGER kid comes and takes out the bigger kid...and so on until it's basically Godzilla taking on voltron.
I'll be there later on in the night. Come out and sus out the 32 Jamie :D
Yeah most likely, you wanna drive across together? Go gym when you get back, thats what im doing
Ok cool!
What time you all wanna going?
Meet at Apple Peel?
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
