140 would be max. But u may find it a bit cooler on the track with 2 laps. We r talking about 5mins max on load. Not. 10-15 min moutain run.
No cooler is not ideal, but safely safely as she goes would be the plan. Catch tank for gtr is what u want tho, from what ive seen the stockers blow a bit (5-6 have done this, u end up with oil dripping from the pods)
My gtst never got over 100deg with the cooler.
Hamish that is hawt!!!
Also i run down a smurf, ran him through the blender and he is know lubing my gearbox :P
so anywhere in the first section is fine? see below pic:
max ive seen it go up is like 3/4 through the first section bit.
Martin said bring a stock GTR and win a trophy by default as most are modded haha :D
Cool :thumbsup:
In other news, wanting to go to winton next month for sau championship - how hot can my engine oil get to safely? because I probably wont have oil cooler installed by then so was thinking of doing hard lap then 2 slow ones or something? or am I being to soft I do notice the gauge go up a fair bit during a hill run when i'm not even pushing the car that hard at all is 140 ish safe to be running on?
hey, im planing on doing winton also dont know how hot the car will get there........but after running it at calder on a 26 degree day and seeing the temp gauge nearly hitting 150 will deff be putting in a oil cooler
all my 6-7 laps were flat out no break fade no real loss of power the car is running motul 300v like john said prob safer doing 2laps on /off but i couldn't resist the speed the car didn't seem to mind too much but wouldn't do it again! mmaybe
my gearbox love's smurfs blood give me more!!!
well, i wasn't broke till i went back to singapore, and lost my waiter job because i left for too long a time..
but yeah, i'm a broke gt-r owner.. a happy one though, just broke..
And i'm saving for a trip to f*kuoka in dec, to have the BEST takoyaki in the whole f**king world.
aight
on the phone to autobarn and the guy put me on hold so im listening to the guy advertising bla bla and they had pokemon music playing in the background
like, when you battle.. that dramatic battle music lmfao
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
