anyone wanna come fishing tomorrow morning meet alvin and i out the front of audi in the city at 4:30 sharrrrpppp
if yall want my number its in my sale listing
and i unclipped the mechanical chin lip cables so im rockin it 24/7 lol
already scraped it while coming out of a carwash
wtf is a chin lip? You talking about the front spoiler?
Yeh that thing.
there is a reason why it goes back up, so you dont damage it when driving slow. It pops down at 80km/h, and works with the button when handbrake is up. Saved me many times, when the bar just makes it over the kerb. Any lip/spoiler would have been destroyed haha
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
