i know kai tracid if that counts ;)
No, it doesn't
OG ain't about how long ya a member or who ya know it's how straight ya got ya head on your shoulders ;)
Yeah true, but we're talkin about wasteland OG's
Me
funky
kamikaze
justin
coupe-this (homo-emo)
tracid (emo)
Kryziisuusdus
jar
Jackie
VL something or other
knee
paul
and probably some I've missed
Ok f**k-arses, it's Vic Wasteland Logic puzzle time...
Question 1)
A man was in a small town for the day, and needed a haircut. He noticed that there were only two barbers in town, and decided to apply a bit of logical deduction to choosing the best one. Looking at their shops, he saw that the first one was very neat and the barber was clean shaven with a nice haircut. The other shop was a mess, and the barber there needed a shave and had a bad cut. Why did the man choose to go to this barber?
not on the skidpan?
track? sounds even more fun, i'm jealous, my R still needs lots of work though, more as of now since i've been rear ended. hahaa.. insurance claims going through nicely though, went for a quote at DT. waiting for them to get back to me too.
Take it to somewhere better seeing as though insurance is paying. I've found an excellent panelbeater in Croydon.
Question 1)
I don't know the correct answer. But the second guy because the first guy mustn't work that hard?
Question 1)
He went to the second guy because he cuts the first guys hair and obviously does a good job...He more than likely gets his own hair cut and beard done at the first barber who is obviously terrible at his job.
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
    • Lock me in mate, although I'm not sure if I'll be heading up from Goulburn or down from Sydney, either way, return will be back to Goulburn
