i know kai tracid if that counts ;)
No, it doesn't
OG ain't about how long ya a member or who ya know it's how straight ya got ya head on your shoulders ;)
Yeah true, but we're talkin about wasteland OG's
Me
funky
kamikaze
justin
coupe-this (homo-emo)
tracid (emo)
Kryziisuusdus
jar
Jackie
VL something or other
knee
paul
and probably some I've missed
Ok f**k-arses, it's Vic Wasteland Logic puzzle time...
Question 1)
A man was in a small town for the day, and needed a haircut. He noticed that there were only two barbers in town, and decided to apply a bit of logical deduction to choosing the best one. Looking at their shops, he saw that the first one was very neat and the barber was clean shaven with a nice haircut. The other shop was a mess, and the barber there needed a shave and had a bad cut. Why did the man choose to go to this barber?
not on the skidpan?
track? sounds even more fun, i'm jealous, my R still needs lots of work though, more as of now since i've been rear ended. hahaa.. insurance claims going through nicely though, went for a quote at DT. waiting for them to get back to me too.
Take it to somewhere better seeing as though insurance is paying. I've found an excellent panelbeater in Croydon.
Question 1)
I don't know the correct answer. But the second guy because the first guy mustn't work that hard?
Question 1)
He went to the second guy because he cuts the first guys hair and obviously does a good job...He more than likely gets his own hair cut and beard done at the first barber who is obviously terrible at his job.
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
