Prob bribed her with a wiggles DVD and some candy
LOL!
Only candy I bribed her with is my lollipop.
Lollipop - Lil Wayne. That shall be my song for tonight.
*Adds to seduction playlist on iTunes*
LOL @ recent topic of pedophilia and Jez working for Playspace.
Haha, yeah I've got a database in front of me with like 80,000 kindergartens, primary schools, childcare centres etc. :whistling:
I'll stick to 17+ thanks.
Btw, 17 year old girl is staying at mine tonight. So much win.
we should hang a bag of lollies off the back of your cars for the lulz
first time involved in an accident so im not sure what happens next...
got everyone's details, kunt at the back that started it agreed to fix all, he's insured with CGU. i don't have any insurance on mine. how do i go about claiming?
He has to call his insurance and get a claim numbers by giving him your information. He then calls you and gives you the claim number. You call his insurance. Give them the claim number and then they will organize repairs
Ah was gonna say if you had full comp you'd probably hope for a write off considering your selling...
Not sure how it works but woulda thought each driver is responsible for the car they hit, not the guy at the end responsible for all. Because if he hit you and pushed you into the car in front, he can argue that you weren't a safe distance from the car in front to begin with...
This is also true. So you got no insurance and the guy u hit is going to need money from you. Not the guy that started it. If te guy you hit has insurance they will be taking you to court over repairs as you don't have insurance
This is why I have full comp
dude infront of me barely had a scratch on his car/rear bar (which is queer since my front bar/cooler are pushed back) he said that he was gonna go after the guy at the end
Doesn't matter what he says man. He won't get anything from the guy in the back. Will sound stupid. But what they will say is that you did not leave enough room between you and the ar infront. You got lucky that it's only a scratch. Follow my first post to get your car fixed
Yip don't like your chances...It's all well and good for the guy at the back to say he's gonna pay for it all, but it's his insurance company that's gotta pay, and if they're not required by law to pay for the cars the rest of you hit, they won't.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
    • So M12 and sealant should be fine?    NPT ” because that’s what I had and what I could get atm.
    • Wouldn’t touch par if they gave it to me. You need to ask how much power you’re looking to make and then add about 50% to it because that’s what you’ll end up making  The factory box says no more at about 350kw or so, the upgraded synchro boxes won’t handle much over 500kw for long and at that point you’re looking at an auto or dog engagement manual,  once you’ve gone dog engagement you may as well go sequential, they cost a little bit more but it’s worth it  also while you’re at it you should upgrade the transfer case with 10 friction plates
