There was one boy in the whole venue, and he was doing sound/lighting shit. If the girls were 2 years older then I would have been loving the ratio. Was still cool regardless though..
I was actually at a high school yesterday with a massive group of girls wanting my autograph and photos with me... :P Gotta love being a muso.
But no, I didn't do anything.. Otherwise I probably would have been locked up haha
You will now be known as Justin bieber
You f**ken liar. They were boys.
bout time you said something amusin mohsen.
having said that your idea of chaining a car to a pylon was hilarious.
I didn't sing it lol. I was just playing backup guitar for this semi-famous singer. He did a pretty damn good job I reckon. Obviously not as good as Bieber though, coz my mate's balls have actually dropped.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
