yeh ill happily take a refund on my membership and fk off this forum for good serisouly.
good example i <3 funky but goes around slammin everyone which is fine, since his a mod an all i call a bloke a pole smoker in an extremely warranted thread and get a warn?
...oh yeh.
dicktatorship much.
shame too there are some good dudes on here and heaps of people who would get more involved if it wasnt run so poorly.
nah i dont care but it still doesnt mean its not fkn bullshit, and IF your gonna have a set of rules in place then implement them properly.
fkn gimps shit me.
nah mohsen its the kents who are 'in' with the mods get away with anything everyone else gets to live in libya.
you keepin your gtr now man?
Yeah not worth selling it, mates decided to steer me away from evos, GTR will make some easy power once i throw a few k at it eventually turn it into a dedicated track car when it starts getting stupid on petrol and using for a daily.
yeh clean car anyway white is best colour :thumbsup:
Few problems underneath and hidden that I'm not to happy about but nothing to major.. will fix it all eventually - guess it is a 98 after all.
I want a black respray! use to have a white 33 N/A
    • Hi, i’m making Vag coil loom for rb25det, can anyone confirm the wire guage i’m using for power supply in diagram is enough for supply not too small for loom? For earth do i need to follow the same procedure or i can use only 16awg wire for all coil and their connecting wire following to the plug?
    • Did you panel beat the dents or have you tried to repair this only using filler?  Is your sanding block soft/flexible and is following the shape of the panel rather then just knocking down the high points?
    • I haven't knocked them down yet. I think I made the repair more complex than it should have been. I had rock chips combined with waviness and dents and I tackled it all in one because it was near each other and just end up wasting a bunch of bog lol. I'll knock down those areas and see how I go. And yep what you are saying at the end is correct. I think I might be sanding the top of a steep hill then my sanding block falls into the dent and gets rid of the guidecoat if that makes sense. Though shouldnt unless I'm covering too big of an area with not a long enough block. I'll try something new and provide some updates. Getting there though! Thanks as always.
    • Yeah makes sense, hard to comment on your situation without seeing what your doing. I was talking generally before, I would not be looking to randomly create low spots with a hammer to then have to fill them.  It's hard without seeing what your doing, it sounds like you are using the guide coat to identify low spots, as you're saying the panel is still wavy. I don't see how you're not ending up with patches of guide coat remaining in a wavy panel? Once the high spots are knocked down to the correct level, surely to have a wavy panel you need low spots. And those low spots would have guide coat still in them?
    • So I'll put filler past the repair area a bit to make sure I don't miss anything. Then I'll block it until it's almost level, put the guidecoat, then keep blocking until it's gone. Then it's still wavy.  In regards to hitting the panel, I saw this video might give more context - Skip to 0:47 he knocks it down. But yeah I'm sanding until the guidecoat is gone then checking because otherwise my filler is still well above the bodyline. Unless what you're saying is I should put guidecoat around it early, surrounding the filler then stip once it's gone?
