Need a memory card for my camera but have no idea what to get. Am technologically retarded. Anyone here have any recommendations that would like to share? Will be taking hundreds of photos. Cost not an issue.
Think of it like this, the average decent quality picture is about 5MB so for every 1GB you get in your memory card is roughly 200 photos you can fit, some of the better quality (higher res) cameras will take photos about 10MB each so obviously that would be 100 photos per 1GB.. get a 8 16 or 32 GB card.. will be sweet :thumbsup:
i see no purpose in taking 5mb photots that are like 4096x2048 though
its just too big for anything useful
unless you have a 25,000 pixel printer at home
pics that are like half the size and half the rest would be just as good
and youd be able to take twice as many
Take me on as a first year and pay me commercial EBA rates. Problem solved.
fine by me but he's being a tight arse lately. Have mentioned you to him once or twice before, no go...
Have you thought about taking up different trade? If I was to quit for whatever reason I'd take up plumbing mainly coz plumbers pwn sparkies money wise. Job's a bit dirtier but meh.
Yeah I always fiddle around with file size, even if you are on a holiday and realize your card is half full.. can just adjust your file size - completely agree 4k + resolution is a bit ghey. (unless its actually your profession or something)
Oh hai! What were you in?
my discgraceful bone stock R32 i was in left lane going straight towards eastlink spotted the cube out of the corner of my eye and was like what the!... ohhhh a cube haha, ive been looking at getting one theres only one for sale in the country with a sunroof and cant get hold of the guy lol :( 1.4L, sunroof, autech kit, 5 seater, some gayass rims
